buildalot05
#1 Posted : Sunday, December 16, 2007 1:22:53 PM(UTC)
buildalot05
Goes through the cycles but will not spin , when put into spin cycle manually hear a sound of like placing a playing card in a fan noise? the lid switch does click. Is it a stripped gear spin cycle?
kawfeeman
#2 Posted : Sunday, December 16, 2007 1:27:58 PM(UTC)
kawfeeman
probably a coupler ( inexpensive part and relatively easy to replace ).. i dont remember part#'s off the top of my head but im sure that abbie or gene do ... ( if you know how to pull the pump and the motor out you can check the status of the couple visually ... )
buildalot05
#3 Posted : Sunday, December 16, 2007 1:36:51 PM(UTC)
buildalot05
THANK YOU VERY MUCH FOR YOUR REPLY, WHEN i LOOK AT THE PART COUPLER WHAT AM i LOOKING FOR TO SHOW THAT IT IS INDEED BROKEN?
kawfeeman
#4 Posted : Sunday, December 16, 2007 1:47:27 PM(UTC)
kawfeeman
the coupler is comprised of 3 pieces... 2 plastic and 1 rubber piece... the two plastic pieces have knubs that fit into the rubber intermediary piece.. the motor shaft gets 1 plastic piece and the trans gets 1 plastic piece and the rubber piece connects the two together .. ( they have been redesigned by W/P to hold up a bit better .. )
buildalot05
#5 Posted : Sunday, December 16, 2007 1:57:28 PM(UTC)
buildalot05
Jim,
When I look at the current coupler that is in the washer what are the signs that it is indeed broken?? will the coupler spin by hand because the knubs are broken off? will I find plastic pieces scattered etc.....??
kawfeeman
#6 Posted : Sunday, December 16, 2007 5:58:32 PM(UTC)
kawfeeman
when you get the pump off to the side and the motor removed, you'll see the two plastic pieces with the 3 knubs ( you'll know where the knubs are supposed to be because the rubber intermediary piece is usually intact and you will see where the 3 knubs from both plastic pieces should fit in to... most likely you will just see the 2 round plastic pieces with no knubs on them...
buildalot05
#7 Posted : Monday, December 17, 2007 6:04:53 AM(UTC)
buildalot05
Thank you for your reply for doing this repair will standard tools wrenches,sockets,screwdriver be good enough ,or will I be required to purchase any specialty tools?
kawfeeman
#8 Posted : Monday, December 17, 2007 6:16:31 AM(UTC)
kawfeeman
all standard tools .. phillips head screw driver, flat head screw driver (large and small ) and a 5/16 hex nut driver would also help.. ( strong forearms and gloves will also help )
Guest (5)
Whirpool washer will not spin (Washer Repair)
by Guest 1/27/2022 11:02:31 AM(UTC)
Washer Will Not Spin Out Water. (Washer Repair)
by Guest 6/5/2021 1:32:58 PM(UTC)
GE Profile Harmony washer will not spin - grinding (WPGT9150HWW) (Washer Repair)
by jmac2287 12/3/2019 11:25:46 AM(UTC)
Washer will not spin (Washer Repair)
by lftfield09 6/9/2017 4:58:09 PM(UTC)
Stacked Washer dryer- washer will not spin and empty (Washer Repair)
by anderson3818 6/8/2017 7:57:48 AM(UTC)
washer will not spin out.. (Washer Repair)
by coastie1160870 1/11/2017 10:41:54 PM(UTC)
GE washer will not spin (Washer Repair)
by MS104 5/10/2016 4:34:48 PM(UTC)
Maytag Atlantis Washer will not spin (Washer Repair)
by lvavis 8/26/2015 7:56:10 PM(UTC)
by howard6168 7/5/2015 5:47:41 AM(UTC)
Kenmore 800 Washer will not spin (Washer Repair)
by AnneKenzie 6/18/2015 12:01:29 PM(UTC)
Frigidaire Washer will not spin (Washer Repair)
by luvmylars 4/30/2015 11:33:25 AM(UTC)
washer will not spin out (Washer Repair)
by kdwarren16yrs 12/27/2014 6:42:50 AM(UTC)
ge profile washer will not spin (Washer Repair)
by ron dog 11/29/2014 5:27:31 PM(UTC)
Washer will not spin/drain (work) (Washer Repair)
by dupdc 8/20/2014 2:50:08 AM(UTC)
Whirlpool Cabrio Washer Will Not Spin (Washer Repair)
by pacdave 5/7/2014 6:40:52 PM(UTC)
