No heat! Changed heating element, thermal fuse, and the thermostat. Still no heat from dryer. Any thoughts on what else it could be?
Your model number seems to be missing a couple digits. I tried the Sears parts site but nothing came up. Kenmore numbers are usually 3 digits, a period and then an additional 8 digits.
I would check the power. The heater requires the full 240 volts but the motor etc. only need 120 volts, at least on most units it is like this.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Do this with the heater off and on. [COLOR="Red"]Be careful as 240 volts is lethal !!![/COLOR] |
THIS FORUM IS DEAD!!!!!!! |
