goff
#1 Posted : Saturday, December 13, 2014 12:14:56 PM(UTC)
goff
Washer fills fine on wash, but will not fill on rinse setting on regular wash or permanent press. Fill valve? Timer??
sidfink43
#2 Posted : Saturday, December 13, 2014 1:25:44 PM(UTC)
sidfink43
Assuming you have the setting on hot for the wash cycle then what is happening is that the hot water valve is opening but the cold water valve is not. So the question is whether the issue is that the cold water valve is not getting power or that the cold water valve is getting power but will not open.
See what happens if the wash temp is set on cold. If water will not come in the problem is likely in the valve assembly. You can confirm this by taking off the cabinet and measuring voltage at the connection to the cold water valve when the machine is calling for cold water.
goff
#3 Posted : Saturday, December 13, 2014 5:55:52 PM(UTC)
goff
Diagnosis correct. switched to cold and no fill. swapped out a solenoid from an old whirlpool i had and it works. Will get part ordered. Thanks.
sidfink43
#4 Posted : Saturday, December 13, 2014 6:02:12 PM(UTC)
sidfink43
Great, that is typically the problem here. Thanks for the update
Guest
#5 Posted : Thursday, April 22, 2021 9:29:53 AM(UTC)
Guest
Hi. My roper top load washer fills fine on wash with both hot and cold water but it only fills to a very low level on the rinse cycle. What is causing this. The circuit board has been replaced recently. It works fine otherwise. Its not a water saving type machine.
Edited by user Thursday, April 22, 2021 10:17:22 AM(UTC)  | Reason: Not specified
Guest
#6 Posted : Sunday, April 25, 2021 3:07:09 PM(UTC)
Guest
I can't find my message in my inbox?
