chuck44l
#1 Posted : Thursday, December 4, 2014 9:26:51 AM(UTC)
chuck44l
Our ice maker went out on the frigidare and i have an extra from a kenmore which i understand is made by whirlpool, The plugs are slightly different with one being a 4 pin with 3 males and a female and the other being a 4 pin all female. Can somebody please tell me which wires to splice together (solder and heat shrink ?) I understand that there are plugs avail but i simply can't afford to buy one. Thanks in advance.
#2 Posted : Friday, December 5, 2014 12:21:31 AM(UTC)
I do not know if I can help but if you provide the model number of the fridge and the part number of the ice maker I may be able to find wiring diagrams for you.
chuck44l
#3 Posted : Friday, December 5, 2014 9:04:01 AM(UTC)
chuck44l
Thanks denman. The re fridge model # is MRS22WNGW6
The ice maker is an older unit. Here are the numbers that i found,
I am unsure which is the model # IM #S 106 626636
The other number is LR 5810 or possibly LR 5010 (My poor old eyes aren't what they used to be) Manufacture date is 08-23-95
#4 Posted : Saturday, December 6, 2014 3:43:35 AM(UTC)
Here are your parts for the fridge.
Parts for Frigidaire MRS22WNGW6 Refrigerator - AppliancePartsPros.com
Here is a better copy on the fridge wiring diagram.
http://manuals.frigidaire.com/p...f/Anderson/218905000.pdf
Nothing comes up using the LR numbers.
The 106 by itself indicates that the actual manufacturer is Whirlpool.
When I search using just 626636 the following comes up.
Part number: AP2984633
I then look that it is used on a Whirlpool ED25RFXFW01.
I have attached the tech sheet for that unit.
So between the two wiring diagrams you may be able to figure out how to wire this in so it will work.
File Attachment(s):
ED25RF.pdf (157kb) downloaded 5 time(s).
chuck44l
#5 Posted : Saturday, December 6, 2014 7:07:49 AM(UTC)
chuck44l
I wasn't able to make anything out on the diagrams as i don't see well. Is it possible for you to call me?
#6 Posted : Saturday, December 6, 2014 9:54:01 AM(UTC)
Sorry but I cannot do.
