kpholler
#1 Posted : Tuesday, December 2, 2014 3:42:57 PM(UTC)
kpholler
Just replaced heating element, thermostat, thermal limiter, and thermistor control and the dryer still will not heat up! Could the problem be in the control panel or is there any other options?:confused:
#2 Posted : Wednesday, December 3, 2014 3:03:32 AM(UTC)
Here are your parts, includes a wiring diagram.
Parts for Frigidaire LEQ2152EE0 Dryer - AppliancePartsPros.com
Here is a tech sheet.
http://manuals.frigidaire.com/p...Webster/134509400efs.pdf
Could be the control board or the centrifugal switch on the motor.
But the first thing to check is the power.
The board, motor and drum light all use half the line (120 volts) but the heater coil requires the full 240 volts.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10/9/2014 8:16:39 PM(UTC)
Maytag Centennial dryer will not heat up (Dryer Repair)
by 1hkfan 10/31/2012 6:51:34 PM(UTC)
Dryer will not Heat up (Dryer Repair)
by jasmineblue27 8/19/2012 12:56:43 PM(UTC)
Dryer will not heat up consistently (Dryer Repair)
by GPDIY 1/4/2012 5:21:02 AM(UTC)
Electric Dryer will not heat up (Dryer Repair)
by varn99 6/2/2011 3:26:17 PM(UTC)
by ray2 5/13/2011 7:10:58 AM(UTC)
by Raljac63 2/10/2010 7:15:09 AM(UTC)
Whirlpool Kirkland Gas Dryer Will Not Heat Up (Dryer Repair)
by LITTLE RED ROOSTER 1/29/2010 9:11:39 AM(UTC)
Kenmore Dryer Will Not Heat Up (Dryer Repair)
by mastaone 11/8/2009 12:44:09 PM(UTC)
Dryer will not heat up? (Dryer Repair)
by mel1293 10/3/2009 12:06:09 PM(UTC)
by Steve T 7/9/2009 7:32:03 AM(UTC)
by clemmy 5/19/2009 7:19:42 AM(UTC)
Dryer Will Not Heat Up - Plug Changed recently from 4 to 3 prong (Dryer Repair)
by Seeking Help 1/11/2009 3:04:44 PM(UTC)
Maytag Gas Dryer will not heat up fully - princeton (Dryer Repair)
by brian.frasco@gmail.com 12/26/2008 1:28:44 PM(UTC)
Whirlpoool dryer will not heat up (Dryer Repair)
by ayellis 4/16/2008 6:47:04 AM(UTC)
