chris hesselgrave
#1 Posted : Friday, November 14, 2014 7:15:16 AM(UTC)
chris hesselgrave
I have been veiwing several of the posts especially threads from Gene. I do not seem to have the defrost timer in my fridge to trip to check that system. What I have found is:
1) Evaporator not frozen. Very light even frost.
2) Evap fan spins, but slowly (maybe 200-300 RPM's?) and I had to start it spinning manually.
3) Freezer gets down to zero, but fridge climbs to 85+.
4) Damper control top center makes odd "grinding" noises when I turn the unit off then back on. The door was shut so I pushed it open. There is still no air circulating in the unit.
5) I have had the unit turned off for 2 days with doors open.
What should I try next?
#2 Posted : Saturday, November 15, 2014 1:18:22 AM(UTC)
I thought I had answered you question in another forum section.
I would replace the fan.
