Boose
#1 Posted : Tuesday, October 28, 2014 9:53:21 PM(UTC)
Boose
Hi:
3 days ago the refrigerator's compressor keep running and never stop,
Freezer not cold enough to freeze anything, botton freezer got good air flow from the back but just not cold enough, refrigerator is not cold as before too.
I check compressor, it's hot and running.
what will be the problems??
model# MBL1957WES2
Maytag Refrigerator just out of warranty few months ago
#2 Posted : Thursday, October 30, 2014 2:42:37 AM(UTC)
You have been a member since:: 2/29/2008(UTC)
Parts for Maytag MBL1957WES2 / Refrigerator - AppliancePartsPros.com
Clicking on a parts description or picture will bring up more info about it.
The compressor and the evaporator fan are running, is the condenser/compressor fan also running?
It should be.
Are the vents in the kick plate and rear cover clean?
Are the condenser coils under the unit clean?
If yes to all the above then remove the cover in the freezer so you can inspect the evaporator/freezer coils.
If there is just frost in one area, usually where the freon enters the coils then it is probably a sealed system problem. This will be an expensive repair as you need a pro. Often it makes more sense to put the dollars towards a new unit.
Be sure that the unit has run continuously for at about an hour before doing this. If you do it shortly after or during a defrost cycle then you may come up with the wrong diagnosis.
If the evaporator coils are heavily iced/frosted over then it is probably a defrost problem. Possible causes are the control board, the defrost heater or the defrost thermostat.
Reply back if you need help narrowing this down.
File Attachment(s):
MBL1957.pdf (169kb) downloaded 6 time(s).
Boose
#3 Posted : Saturday, November 8, 2014 7:13:10 PM(UTC)
Boose
Hi denman:
compressor and the evaporator fan are running.
condenser and compressor fan also running.
I also cleanup condenser coils.
condenser coils under the unit doesn't blow warm air out and it's not warm/hot when touch by hand.
I like to upload an mage to show evaporator/freezer coils, but i don't know how.
evaporator/freezer coils got some frosted on it, not a lot, I use hair dryer can melt it in few minutes.
#4 Posted : Sunday, November 9, 2014 12:43:04 AM(UTC)
[COLOR="Blue"]evaporator/freezer coils got some frosted on it, not a lot,[/COLOR]
How the frost covers the coils is important.
It should be fairly even.
Below is a link take a look at the example pictures about a third of the way down the page. They show sealed systems with problems.
http://www.applianceaid.com/ref...ator-not-cold-enough.php
