top load washer wont aggitate, only goes in one direction when turned with hand. spin and rinse cycle work..any help would be great! thanks
Originally Posted by: hawkinscollette ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ...spin and rinse cycle work.. Does it agitate during the rinse cycle? Gene.
no it does not aggitate at all just spins
Remove the front panel and the belt. Check if the transmission pulley can be moved in both directions.
