On Thanksgiving morning the radiant top and oven were working. At the end of Breakfast they quit. The clock, oven settng temp, etc. display still works. I reset the circuit breaker. When I turn on the element, it immediately clicks and the light on the panel flashes. The oven shows all signs of working except that it doesn't heat anything either. I had the control panel replaced 4 years ago with the improved Sanyo model. UPDATE=============== It turns out the circuit breaker itself failed. It was a Murray 40/30 quad. I replaced that. (hard to find) But I still have a problem. The radiant element on the left side actually has 3 elements in it. A round front, a bridge element and a round back element. The rear element is not working now. Everything else is fine. I would appreciate any advice on how to get that one working.
One element is not working. Any advice here?
