jbritton@evisionsys.com
#1 Posted : Sunday, September 28, 2014 9:08:26 AM(UTC)
My Kitchenaid dishwasher will not run and it makes a humming noise when the cycle should be starting.
#2 Posted : Monday, September 29, 2014 2:55:06 AM(UTC)
Parts for KitchenAid KUDL03FVSS4 Dishwasher - AppliancePartsPros.com
Here is a manual which may be useful even if it is not for your specific model.
You will have to join the site and be logged in to be able to download it.
http://appliancejunk.com...&id=234;t=1411987020
First I would check that the motor armature turns manually (nothing jammed in the impeller or chopper).
Next would be to check the motor windings with a meter.
Then check that the motor gets 120 volts when it should.
