Parts for Kenmore Dryer 11063012101 - AppliancePartsPros.comIf you go to the Sears parts site they have part breakdown diagrams which they do not share with other vendors.
See the attachment for your wiring diagram.
There are lots of possible causes for no heat.
First I would check the power to the unit. The heating element requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
Next unplug the unit and check the heating element with a meter.
If OK then check the thermostats.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
