gregger77
#1 Posted : Friday, August 22, 2014 5:13:10 PM(UTC)
gregger77
Hi,
I have a Goldstar DH40 40-pint portable whose compressor has stopped running.
The unit still powers up and the fan runs, but the compressor doesn't kick in.
I checked the humidistat with a voltmeter and there is variation in the ohms reading, so it appears to be functional. When I disconnect the humidistat from the board, still no compressor run (although I don't know if that simply "opens" the contact and keeps it from firing up.)
I pulled the board and checked the quality of the solder joints on the back for the relay and transformer. Both appear very sound; the whole boards looks very good.
Now I'm wondering if it's the capacitor, or the start relay itself, but I don't know how to check those.
The unit is 10 years old and cost about $200. It replaced another 40-pint Airtemp unit which cost $200 and did the same thing (compressor stopped firing up) after about 6 years of use. (That one is collecting dust under the basement stairs, thinking it's going to get fixed, too!)
Should I just accept that these things are disposable, ie., not worth the time/parts to fix? Seems so wasteful, since every other aspect of the machine seems sound, to chuck it because some $1 or $2 electrical component fails.
Advice please. Basement if getting a bit damp and wifey is ready to go shopping...
#2 Posted : Saturday, August 23, 2014 7:24:47 AM(UTC)
Here is a decent site on how to check a compressor etc..
How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com
Note that the winding check will tell you if a compressor ios bad but does not tell you that it is good. As it may have a winding to winding short or mechanical problems.
Getting parts for it may be a pain!!!
