ejditz3
#1 Posted : Monday, August 4, 2014 1:15:39 PM(UTC)
ejditz3
Our washer stopped agitating during a wash cycle and blew the breaker. It hums but won't spin or agitate on any cycle. I pulled the motor and checked it and it works. The coupler assembly is fine. The transmission spins freely in both directions. I don't know what else to check. Please help
fairbank56
#2 Posted : Monday, August 4, 2014 4:02:14 PM(UTC)
fairbank56
Could be something jamming the drain pump, did you try running it with pump pulled away from the motor?
Eric
ejditz3
#3 Posted : Monday, August 4, 2014 4:05:47 PM(UTC)
ejditz3
I just tried to turn it manually with a screw driver and it will not turn. Should I attempt to clear it or just replace it? Thanks
fairbank56
#4 Posted : Monday, August 4, 2014 4:43:15 PM(UTC)
fairbank56
Take the hoses off and check inside, might be a sock stuck in there. Put a pan under it first as there will be water in there.
Eric
ejditz3
#5 Posted : Tuesday, August 5, 2014 10:22:56 AM(UTC)
ejditz3
Thank you so much for your input! There was, indeed, a sock stuck in the drain pump. It works great again
