setnamyor
#1 Posted : 11 years ago
setnamyor
Only the bottom part of the Freezer and Fridge is cold.
richappy
#2 Posted : 11 years ago
richappy
Remove the freezer back panel and describe the frost pattern.
#3 Posted : 11 years ago
Also does the evaporator/freezer fan run?
It should be on when the compressor is on.
One caveat is that there is a delay just after e defrost cycle.
I am off to the cabin for a couple days so will not be available.
Richappy should be able to give you any additional help if you need it.
He knows a lot more about fridges than I do.
