jdh022764
#1 Posted : Monday, July 14, 2014 7:55:37 PM(UTC)
jdh022764
has anyone heard of a restrictive capillary tube and how it can be fixed?
richappy
#2 Posted : Tuesday, July 15, 2014 8:13:48 AM(UTC)
richappy
You have no cap tube clog, but if the best the freezer can do is 20 degrees, you have either low refrigerant, a bad compressor, or both.
jdh022764
#3 Posted : Tuesday, July 15, 2014 5:32:46 PM(UTC)
jdh022764
ill sum up what started this, the icemaker stopped working properly so I check both sets of water solenoids and everthing seemed ok, then I realized the freezer temp was only 20 to 25 degrees and the compressor would only stop for the heating element cycle then the freezer warmed up more, I decided to add some r134a with a subco adaptor then the return line from the evap to the compressor froze up, then I read appliance mans response and I thought he got it right , with a restricted not a block cap tube or possibly a drier restriction, thank you for your response I would love to read more from you about this.
richappy
#4 Posted : Wednesday, July 16, 2014 12:25:50 AM(UTC)
richappy
The frost line should not be near the compressor, remove som refrigerant till it backs off, then check freezer temps.
