azure012
#1 Posted : Friday, July 11, 2014 6:41:40 AM(UTC)
azure012
What a fantastic forum! I am so glad to have found it.
My dryer is making a strange noise. It starts about two minutes after the flame ignites. (no noise on air fluff).
The noise starts at the 0:08 mark. https://www.youtube.com/watch?v=S4MSol832NE
I checked continuity on the high limit and cycling thermostats. Replaced drum rollers, pulley wheel and glides. Blower wheel seems fine.
Thank you for any help you can provide!
Colleen
Traveller555
#2 Posted : Friday, July 11, 2014 11:00:23 AM(UTC)
Traveller555
I hear 2 noises going on in there. One sounds like it's electronic related almost like a relay and the other sounds like a normal tumbling sound. I wouldn't of thought it would be rollers. Very strange sound to say the least.
azure012
#3 Posted : Friday, July 11, 2014 11:51:40 AM(UTC)
azure012
Thank you for your reply! I actually took that video before replacing the above mentioned parts, so the tumbling is much quieter now, but the noise that starts at 0:08 is still there. It is definitely heat related since it only happens a couple minutes after it fires up. It will continue when the flame goes out though (cool down cycle) so it is not related to the gas valve (?).
Maytag dryer noise (Dryer Repair)
by Cmjb13 9/7/2017 7:20:37 PM(UTC)
Maytag Dryer Noise (Dryer Repair)
by chawkins@wvi.com 3/3/2009 9:37:25 PM(UTC)
