klondike
#1 Posted : Tuesday, June 24, 2014 3:14:42 PM(UTC)
klondike
Replaced motor in my a308 maytag washer and it still won't work. Checked power to motor in different cycles and only have power at the black wire.
klondike
#2 Posted : Tuesday, June 24, 2014 3:21:50 PM(UTC)
klondike
replaced motor in my model a308 washer and it still won't work. checked for power in different cycles and only get power to the black wire. motor will not kick in even with power to black wire. I grounded motor to frame like he old one.
fairbank56
#3 Posted : Tuesday, June 24, 2014 4:15:22 PM(UTC)
fairbank56
This is a single speed motor with a run winding and a start winding. You should have 120vac hot side to black, neutral to red. Start winding is green and yellow wires. Hot to yellow, neutral to green for agitation direction, hot to green, neutral to yellow for drain/spin.
Eric
