Paul_illinois
#1 Posted : Monday, June 16, 2014 7:53:28 PM(UTC)
Paul_illinois
Views messages in topic : 13
Howdy gents,
I've been investigating the cycling thermostat in my 1990's non-electronic Whirlpool QuietWash, because the dishwasher suffers the common problem of a looong wash cycle. I can force the wash cycle to run normally by shorting the thermostat.
Initially, I jumped to the conclusion that my problem was the cycling thermostat, because the water (and element) seems hot during the wash cycle. The element works fine (very hot! ouch!!) during the dry cycle.
Is it possible for the element to work fine during the drying cycle, and yet be unable to fully heat the water?
Here are my measurements of water temperature:
  • my tap water = 120°
  • dishwasher pre-wash cycle = 105°
  • dishwasher wash cycle at start = 112°
  • dishwasher wash cycle after 10 minutes of heating = 125°
I haven't tried measuring real-time amps during wash cycle & drying cycle because the element connectors seem to be hardwired - I don't wanna risk damaging the connector or rubber seals because this old element is no longer for sale. And, unfortunately, I don't know anyone with a clamp-on ammeter.
Thank you!!
Paul_illinois
#2 Posted : Sunday, June 29, 2014 7:43:28 PM(UTC)
Paul_illinois
#3 Posted : Wednesday, July 2, 2014 2:38:30 AM(UTC)
Parts for Whirlpool DU8950XX0 Dishwasher - AppliancePartsPros.com
And here is a link to the operators manual.
http://www.whirlpool.com/digita...0Guide%20-%203369098.pdf
Yes because the circuit paths are different.
Could be a timer contact problem.
Looks like contact 6 should be closed to heat the water.
File Attachment(s):
DU8950.pdf (67kb) downloaded 5 time(s).
