penninger7142
#1 Posted : 16 years ago
penninger7142
Hello!!
My wash machine will not agitate. It works just fine other wise. It fills and it draines and duringthe final rinse the main drum does spin, however, the agitator does not. I have double checked that the pully is working and it does appear to have enough tension on it. I'm also able to move the agitator freely with my hand and I'm not sure if I'm suppose to be able to do that either.
Any advise or direction you can point me in would be great.
applianceman
#2 Posted : 16 years ago
applianceman
No you shouldn’t be able to turn the agitator by hand. The agitator-coupling is bad. To replace it just lift up on the agitator and the agitator-coupling is right under it held on by a 7/16 screw. GE Washer Not Agitating Repair Guide
penninger7142
#3 Posted : 16 years ago
penninger7142
Thank you for your quick responce. Once I get the agitator off, and from what I have read, it's a bear to get off. Is it easier to get back on?
GE Washer Not Agitating or Spinning (Washer Repair)
by Gator84 10 years ago
by KerriH 12 years ago
GE washer not agitating (Washer Repair)
by rfm1 12 years ago
GE Washer Not Agitating (Washer Repair)
by eosada 12 years ago
GE washer not agitating properly (Washer Repair)
by aav 13 years ago
by skeeskinner 13 years ago
by Ellen Clark 14 years ago
GE Washer Not Agitating, Transmission Fine (Washer Repair)
by silvz72 15 years ago
