AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
whirlpool dryer starts then stops in twp seconds
Dryer starts, then stops within two seconds. Will start with start button immediately, but stops agin in 2 seconds. WIll restart many times, but fails to continue running. ONLY IF I HOLD THE START BUTTON, it will make an odd noise and thermal out, not starting again for a few minutes. BUt, just hitting the start buton will start, release the button annd it stops within 2 secs, and this can be done repeatedly. Loosening the belt on the motor pulley does not change anything.
Evidently the starter windings were good, but the Run windings were bad. A new exact replacement motor solved the problem.
Dryer Repair
