jh109052
#1 Posted : Sunday, May 4, 2014 10:14:08 AM(UTC)
jh109052
The clock and timer are working fine. The stove top, oven and broiler are not working at all....Is this repairable ?
#2 Posted : Monday, May 5, 2014 3:22:28 AM(UTC)
Parts for Maytag PER5710BAW Range - AppliancePartsPros.com
Following is a service manual. Although it doeds not list your unit it should be s close match.as your unit is likely to be close to a MER5710 whose wiring diagram is on page 4-60.
You will have to join the site and be logged in to be able to download the manual.
http://appliancejunk.com...ownloads;sa=view;down=25
Since the stove top elements and oven element are wired separately in the unit
the first thing to check is the power. If you lose the 240 volts then all elements will not work but the timer etc. will.
L1 to L2 should be 240 volts
If OK
If OK
