melindai
#1 Posted : 11 years ago
melindai
my washer will not spin at the beginning and makes a funny noise and then shows a LE code and that is even with one piece in it
please help thanks:confused:
Larry75243
#2 Posted : 11 years ago
Larry75243
I looked this up (I'm here looking for something else for an LG washer) and it shows in the service manual that an LE means Locked motor Error).
Here are the items shown in the service manual to have checked:
The connector (3-pin, male, white) in the MOTOR
HARNESS is not connected to the connector
(3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors
(3-pin, male, white) in the MOTOR HARNESS
and 4-pin, female, white connector in the MAIN PWB
ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR
ASSEMBLY and MAIN PWB ASSEMBLY is cut (open
circuited).
• The hall sensor is out of order/defective.
Before doing anything else, I would be sure to check that hall sensor and I can bet they have them here on the site. I read on another repair site that depending on age and use of machine those are a common error and better to check and replace that sensor before wasting money on the motor.
The manual is calling it a "hall" sensor but in reality it is a rotor position sensor.
http://www.appliancepartspros.c...01kw2002a-ap4440680.html
Here is the repair video from this site:
http://www.appliancepartspros.c...2a-ap4440680.html#videol
Hope this helps
LG front load washer part id (Washer Repair)
by Cgreen0117 12 months ago
LG front load washer water leak (Washer Repair)
by Guest 3 years ago
LG front load washer making grinding noise (Refrigerator & Freezer Repair)
LG Front Load Washer rotor only turns if given a push. (Washer Repair)
by Emailtim 5 years ago
LG Front Load Washer Barely Spins (Washer Repair)
by mckennwa 8 years ago
LG front load washer repair- special LG tool to remove the door front seal spring rin (Washer Repair)
by Paul Lukitsch 11 years ago
LG front load washer (Washer Repair)
by reichegw 12 years ago
LG front load washer no power (Washer Repair)
by waxmanak 12 years ago
Leaking LG front load washer (Washer Repair)
by klinkster 14 years ago
Lg Front Load Washer (Washer Repair)
by GIACOMO21 14 years ago
LG front load washer (Dishwasher Repair)
by skimanforu 15 years ago
by Brandon1974 16 years ago
