2 Pages12>
Dirty Stinkin' Hippy
#1 Posted : Thursday, April 3, 2014 4:03:10 PM(UTC)
Rank:: Member
... speaking of Old Horses, I tried to rustle up a fix to a dryer heating issue on our old Whirlpool LAE5800W0 and created another. Yeah, it's been fixed a few times already, but NEVER SAY DIE.
The Original Problem: Heating Element shot.
Fix: New Element, three Thermostats. Going blind a bit, no multimeter reader here, but I figgered if I'm replacing the heater, who knows what shape the thermostats are in?
After a quick test, it worked! Eurekum! I was jazzed enough ( yeah you know freaks love that crazy beat ) to throw in a load. The clothes were drying! I was a Happy Hippy.
Errr ... Mebbe Not. Within five minutes the lights were flickerin' and I heard a few pops. Knowing it wasn't my Marshall amp shorting out, I unplugged the unit. The breaker didn't trip, but I was on a bad one. Totally bummin', I let the Whirlpool rest a day.
I went back downstairs today and opened up the back to discover the source of the short: The black and white wires leading to the Starter had melted to the Heater Body. In my roundabout haste, meaning hours devoted to this project, I neglected to tie the old wires together AWAY from the heater before closing up the cabinet. I pulled the wires away, taped them up, grouped them all together and tied them up near the blower, FAR from the heater. Closed it up, plugged it in. I thought that was the end of it.
I turned the Timer to position and pressed Start. Nuthin'.
The New Problem: Seems I shorted out the Starter Switch after all. When I realized the short, the whole unit was working, so I hoped that I shut it down in time before damage occurred. It's got power, the Timer ticks, so that suggests that I fried the Starter Switch only. Hopefully.
My Question: Below is the schematic. How can I be sure it's just the Starter? If someone is kind enough to offer advice, I will repay that with a followup result.
Moral of the Story: Never work whilst stoned. :p
I want to thank the kind souls who help here 'cuz you've helped us in the past as I've lurked here for some time. Fixed this thing twice now and our washer twice as well. If that seems nutty, I'd agree, but really, do computers belong in laundry machines? Tell me the new ones are what they seem to be.
Thanks in Advance,
A Dirty Stinkin' Hippy
Dirty Stinkin' Hippy attached the following image(s):
#2 Posted : Friday, April 4, 2014 2:18:57 AM(UTC)
Parts for Whirlpool LAE5800W0 / - AppliancePartsPros.com
Get a meter and check it.
With switch just sitting there C (common) to NO (normally open should be infinite ohms. C to NC (normally closed) should be 0 ohms.
With the switch activated C to NO should be O ohms and C to NC should be infinite ohms.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
#3 Posted : Friday, April 4, 2014 7:10:14 AM(UTC)
Rank:: Member
Thanks, Denman! I know it's an unfair question without a meter, but I thought a simple jump might indicate something, 'cuz that's all I got! You're right, meters are cheap as dirt, but I have my sights set for a Aromatherapy Lava Lamp from The Sharper Image ...
#4 Posted : Friday, April 4, 2014 10:36:33 AM(UTC)
You could short the Normally Open to the Common and give it a try.
#5 Posted : Friday, April 4, 2014 6:42:42 PM(UTC)
Rank:: Member
Haven't done that yet, tomorrow.
Meanwhile, I did without my weekly ZigZag purchase and sprang for a Craftsman $20 tester.
Here's what I found:
First, tested Circuit Breaker. OK.
Control Panel Parts
Temperature Switch
1. Tested Air Fluff setting, between the Red and Black terminals.
Continuity: Buzzed ( >30Ω ). Readings wonky, up and down in the hundreds,
guessing it takes time for readings to settle.
Resistance: 5-80Ω. Readings wonky again. I assume a low of 5 means it's OK.
2. Tested High Temp setting, between the Red and Black terminals.
Resistance: 2.2Ω was the low.
Conclusion: Didn't bother testing the Low setting, I assume this part is OK.
Start Button
1. Tested between the Red and Black terminals.
Open when button not pressed.
2. Button pressed.
Resistance: 0Ω. Nearly perfect reading.
Conclusion: My assumption is wrong. This part is OK.
Cycle Signal
1. Tested between the Red and Blue terminals.
Continuity: No buzz; readings in 1000s.
Resistance: Readings in 1000s.
Conclusion: Either this part cannot be tested, or it's BAD.
Timer
1. Tested between the Gray ( TM1 ) and Black terminals.
These are at the top of the Timer, side by side.
Rotated dial while testing.
Resistance: 0Ω. Perfect reading.
Conclusion: Lucky me, probably don't need a Timer. BUT, there are other terminals.
Cabinet Rear Parts
All Three Termostats
1. Tested between the opposite terminals and ignored third "middle" post.
Resistance: 0Ω.
Conclusion: All three Thermostats seem OK.
Heater
1. Tested both Red posts; removed just one wire.
Note to Readers: Careful here. These connections easily prone to damage.
Resistance: 10Ω. A low of 10; went higher. I assume this is normal.
Conclusion: If 10 Ohms is normal, then Heater is OK. I hope.
Didn't dig deeper to the Motor. I really don't wanna deal with that Cabinet again.
Any thoughts out there?
As Always, Thanks for Reading and Advising,
#6 Posted : Saturday, April 5, 2014 1:53:01 AM(UTC)
Set the meter to it's most sensitive resistance scale.
Before starting short the meter leads together so you can see if there is a zero offset in the meter.
Set the timer to mid cycle of a problem cycle.
Unplug the unit
Attach one meter lead to L1 prong on the power cord and leave it there.
Black on the terminal strip should be 0 ohms.
Both Y and BC at the timer should be 0 ohms.
C and NO at the start switch should be 0 ohms when the start switch is pushed.
5M at the motor should be 0 ohms.
4M at the motor should be a couple ohms (motor windings)
D at the door switch also a couple ohms.
D1 at the door switch a couple ohms when the door is closed.
There that is pretty well the motor circuit checked.
#7 Posted : Saturday, April 5, 2014 6:15:52 AM(UTC)
Rank:: Member
Thanks again, Denman.
While gone, I jumped the Cycle Signal, also commonly known as The Annoying Buzzer, and no dice.
So, I'll proceed with your posted steps and check the Motor. Your way is LOTS easier than dealing with cracking open that Cabinet Panel. It's bent more than my brain. Getting those Panel Clips to line up is a bear.
The final step, probably the most obvious one, is to replace the burnt wire. You think it's safe enough to splice them with spade connectors? Don't see how it could hurt.
#8 Posted : Sunday, April 6, 2014 10:20:46 AM(UTC)
Rank:: Member
Update:
Block Strip and Timer contacts checked out per your instructions. Read .2Ω so I assume that's OK. Package on Multimeter indicates accurate within two digits. Close enough to 0Ω.
Door Switch has continuity but may be wonky; resistance inconclusive.
Jumped both Buzzer and Door Switch, no dice! On to the Motor. Which means I'll have to crack that Cabinet AGAIN. Not happy.
I will try to splice the White wire that got fried; hope I have slack. I'll lose 6 inches doing this. The other Black wire that touched the Heater housing also spliced but this did nothing.
Grrr ...
PS: One good thing that's come of this, if there is such a thing: I found an old drill bit I've been missing for three years. Where'd I find it? Yup ... in the Lint Chute! Also found the Lint Seal is completely gone. Time to order a new part!
#9 Posted : Sunday, April 6, 2014 10:30:18 AM(UTC)
Rank:: Member
Note to Readers: A newb at Multimeter Reading here. Don't fret if you find the numbers dancing all over the place, keep holding the points steady on the device you're testing. It'll take several seconds but the reading should settle on what you're looking for. I didn't splurge for Alligator Clip leads, so I used my daughter's alligator-type hair clips to hold the leads in place. Tape would be better but that's messier and could gum up the parts a bit.
#10 Posted : Sunday, April 6, 2014 1:29:41 PM(UTC)
Rank:: Member
Test Conclusion: Most of my readings of new and old components at the lowest, most sensitive setting, 200Ω, were .2Ω.
The Motor was another issue. The readings at the 5M ( White ) and 4M ( Blue ) posts were 2.2Ω at the 20kΩ setting, and 1 at the lower settings. I also bothered to measure the 6M ( Black ) post. That read 0Ω at the lowest setting.
At the very least, the 5M wire needs to be replaced. But the 4M reading indicates I FRIED THE MOTOR.
Damn.
Is it possible to get by with a new Motor Switch, or throw in the towel?
2 Pages12>
