peterkirt
#1 Posted : 11 years ago
peterkirt
When I press the start button, I get a loud buzz from the timer switch and no attempt to start. The push start button checked out okay. I am assuming the timer is toast. Prior to this, the heat output and drum rotation was fine. I just thought I would check this with you folks before I start throwing parts at it !
#2 Posted : 11 years ago
Here are your parts. Includes a wiring diagram with a timing chart.
Parts for Maytag SDE3606AYW Dryer - AppliancePartsPros.com
It does sound like a timer problem as long as you are sure that it is the timer or end of cycle buzzer that is buzzing.
You could check the timer contacts with a meter to confirm this.
The reason this is important as sometimes the main motor will buzz if it does not start.
peterkirt
#3 Posted : 11 years ago
peterkirt
Thanks ...
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest about a year ago
Old whirlpool electric dryer won't start (Dryer Repair)
by era300 10 years ago
GE Electric Dryer won't start (Dryer Repair)
by brosnan 10 years ago
Kenmore 70 Series Electric Dryer Won't Start (Dryer Repair)
by rdtraverse 12 years ago
Estate Electric Dryer won't start - Checking continuity on Timer switch? (Dryer Repair)
by scottietj 13 years ago
Kitchen Aid Electric Dryer Won't Start (Dryer Repair)
by ihtractor 13 years ago
by cakst35 13 years ago
trouble shooting electric dryer won't start (Dryer Repair)
by Domenic711 13 years ago
Maytag Electric Dryer Won't Start (Dryer Repair)
by Rosebud42 13 years ago
Electric Dryer won't start has power (Dryer Repair)
by coxc6419 14 years ago
Maytag neptune electric dryer won't start (Dryer Repair)
by area123 15 years ago
by fridayauction 15 years ago
by WhittierM 15 years ago
GE electric dryer won't start (Dryer Repair)
by aqrose 15 years ago
Maytag Electric Dryer won't start,no sound (Dryer Repair)
by Pennell 15 years ago
