ve2zc
#1 Posted : Thursday, March 13, 2014 11:24:43 AM(UTC)
ve2zc
Hi
I have Whirlpool model GLP85800 If I try to put it into the cleaning mode, it reads "door" and does not begin. I checked the door switch with a meter and it works correctly. The oven operates normally, any help with this problem
Dan
#2 Posted : Saturday, March 15, 2014 1:09:01 AM(UTC)
Parts for Whirlpool GLP85800 Range - AppliancePartsPros.com
Not sure which door switch you checked.
The one for the door latch sensing is Item 23 in section 04.
It tells the control board that the door is locked and it can proceed with a self clean cycle.
File Attachment(s):
GLP85800.pdf (171kb) downloaded 2 time(s).
ve2zc
#3 Posted : Saturday, March 15, 2014 10:50:00 AM(UTC)
ve2zc
Thanks, let me check and will let you know
Thanks again
Dan
Oven Self Cleaning Problem (Oven Repair (including Ranges and Cooktops))
by double-g 1/16/2011 8:14:09 AM(UTC)
