dennisthemenace
#1 Posted : Monday, February 10, 2014 8:35:36 AM(UTC)
dennisthemenace
back on 12/16/2013 posted original info. screens clean, has power, drum free, only spins once then quits. lid lock functions ok. Fairbanks 56 suggested shift actuator motor. got sick & didn't get to it till recently. just went to replace the part and found belt almost off small pulley & large pulley loose. how much freeplay on large pulley? would shift actuator cause belt to come off? found tech sheet but washer is apart. can I still test shift actuator at console?
fairbank56
#2 Posted : Monday, February 10, 2014 12:37:59 PM(UTC)
fairbank56
Loose nut on that pulley is a common problem. Take nut off and apply loctite blue 242 threadlocker to the threads and retighten nut.
Eric
whirlpool washer wont fill (Washer Repair)
by dennisthemenace 12/16/2013 7:45:20 PM(UTC)
Whirlpool washer wont fill (Washer Repair)
by whipskipper 9/8/2012 3:55:32 PM(UTC)
Whirlpool washer wont fill with water. (Washer Repair)
by dfwhip 12/10/2007 8:03:07 AM(UTC)
