pete8960
#1 Posted : Thursday, March 25, 2010 7:47:46 AM(UTC)
pete8960
I have a GE Profile Spectra xl44 and the oven will not turn on. I have taken off the bottom plate to expose the burned and the ignitor. When I turn the broiler on the ignitor glows red and the flame turns on. When I try to do that with the oven, the ignitor does not glow at all and the flame will not kick on. I assume its the ignitor that has gone bad, but I wanted to make sure before I pay for the part and shipping that I am on the right track.
#2 Posted : Thursday, March 25, 2010 5:15:33 PM(UTC)
Check if there is 120 VAC to the Bake igniter while the control calls for Bake.
If there is proper power, replace the igniter.
If there is no proper voltage, post the results and we'll go further with the diagnosis.
- The Bake igniter Part number: AP2014008
Navy mom
#3 Posted : Friday, February 7, 2014 6:58:37 AM(UTC)
Navy mom
I have a GE PROFILE SPECTRA XL44
The Self cleaning oven part works the light on top works and when I try to use my oven the numbers light up and it won't heat. This happened a couple months ago and I cleaned it again and it work heating again for a short time but now it will not heat at all. You can set it to the temp you want the oven on all that lights up but no heat.
Frigidaire wall oven model CGEB30S8CS1 oven will not turn on (Oven Repair (including Ranges and Cooktops))
by RHykawy 4/2/2021 2:00:36 PM(UTC)
GE Profile electric oven will not turn on (Oven Repair (including Ranges and Cooktops))
by toddlamp 3/31/2021 7:03:39 PM(UTC)
Frigidaire Gallary Electric Range Oven Will Not Turn On (Oven Repair (including Ranges and Cooktops))
by jaycevs 12/2/2014 5:28:35 AM(UTC)
Jenn-air double wall oven - lower oven will not turn on (Oven Repair (including Ranges and Cooktops))
by hjustice 9/28/2014 11:37:55 AM(UTC)
GAs range oven will not turn on (Oven Repair (including Ranges and Cooktops))
by JohnRogers 4/18/2013 8:21:57 AM(UTC)
Oven will not turn on (Oven Repair (including Ranges and Cooktops))
by Bkomperda 2/6/2013 2:59:00 PM(UTC)
Maytag oven will not turn on (Oven Repair (including Ranges and Cooktops))
by threeputt 12/10/2012 12:07:16 PM(UTC)
Need to bake/ oven will not turn on! (Oven Repair (including Ranges and Cooktops))
by ms michelle 1/24/2011 3:05:15 PM(UTC)
Frigadiare Oven will not turn on (Oven Repair (including Ranges and Cooktops))
by 29264 3/17/2010 10:58:24 AM(UTC)
by mcarp 9/25/2009 3:28:57 PM(UTC)
Kenmore gas oven will not turn ON (Oven Repair (including Ranges and Cooktops))
by skidoomxz99 8/20/2009 3:42:25 PM(UTC)
by rortega 7/11/2009 9:15:43 AM(UTC)
by CTHEESFELD 7/10/2009 6:30:11 AM(UTC)
Oven will not turn on, broiler works, stove top works (Oven Repair (including Ranges and Cooktops))
by caewart 6/19/2009 4:31:43 PM(UTC)
by craigjung 3/1/2009 1:21:19 PM(UTC)
