My Frigidaire front load washer is acting like it is out of balance whenever it spins. I receive no beep codes, and it doesn't slow down and readjust the load as it usually does when it is actually out of balance. It continues spinning at full speed and it completes the spin cycle, but it makes the usual out of balance noises like loud thunks and vibrations. It started about a week ago and is doing it for every load, regardless of the weight. I think something has shifted or broken loose. Any ideas where to look?
Your model number is coming up as a dishwasher.
What is likely the problem is the support structure is broken. Take off the top and see if you can determine where the problem is. If you need more assistance check and post the model number and we may be able to link you to a service manual.
