iclad
#1 Posted : Tuesday, January 28, 2014 12:53:59 PM(UTC)
iclad
on all drying cycles this dryer will shut off after one minute and display a ce fault
the vent line is lint free and the run is less than 6 ft
the fault appears even if the vent is disconnected allowing free flow
there have been a few times where the dryer continues to run
masterquinn
#2 Posted : Wednesday, January 29, 2014 5:53:14 AM(UTC)
masterquinn
The CE error stands for “Communications Error” and refers to a breakdown in communications between the machine controller and the motor controller. this problem is usually caused by a bad wire connection. The most common trouble spot is the quick disconnect at the motor connector. Usually, if you just take off the connector and re-attach it, that clears it up.
another common problem is a blown fuse on the motor controller board. in this case, you need to replace the entire motor controller board. im leaning toward the wire connection, though, because you say that in some instances it continues to run.
iclad
#3 Posted : Thursday, January 30, 2014 2:38:33 PM(UTC)
iclad
thank u
i was thinking it meant clear or check exhaust
for a laugh
a quick story
with that thought in mind i have been suspecting
the moisture sensor
don't ask me how i got there reasonably
and have been wiping the sensor with a wet rag
b4 starting a new load
as i rite this i can hear my third load drying without issue
if it returns to pesky i will follow your instructions
before i buy a new board
thanks
tom
