nomifish07@aol.com
#1 Posted : Saturday, January 25, 2014 12:46:17 PM(UTC)
nomifish07@aol.com
I have an admiral washer that has stopped filling. it will spin but wont fill with water. PLS HELP!!!!!:confused:
fairbank56
#2 Posted : Saturday, January 25, 2014 3:20:20 PM(UTC)
fairbank56
Do you have a multimeter and experience using it? Problem could be caused by bad timer, water level pressure switch, temperature switch, temperature sensor, water inlet valve assembly. Need to use meter to determine which, otherwise, just guessing and throwing parts at it til it's fixed. Assuming you have good water pressure at hoses and any screens in hoses and water inlet valve are not clogged.
Eric
