Lindaslats
#1 Posted : Sunday, January 19, 2014 2:50:52 PM(UTC)
Lindaslats
Dryer won't run. Has power,all buttons work and light up. When start button is pushed, door lock clicks but dryer does not start. Ran panel diagnostics. Door switch checks out ok. Moisture sensor shows "02" in window rather than "03" which is what instructions say should display. Console switches: all work and beep when pressed; except when pushing start button, "06" is displayed rather than "01" . Any ideas?
fairbank56
#2 Posted : Sunday, January 19, 2014 5:57:32 PM(UTC)
fairbank56
First, check the belt. If it's broken, motor won't start. If ok, you need to check voltage at P-1 connector on machine control board. Check for 120vac between light blue wire and white wire when you press the start button. If you don't have it, the control board is bad. If you do have it, check it between light blue and blue wires. If not there, door switch is bad. If you have it there as well, then check the thermal fuse. If thermal fuse is good, check the belt switch.
Eric
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
Kenmore Elite dryer won't run... (Dryer Repair)
by J C Jones 9/11/2021 9:09:42 AM(UTC)
Kenmore elite dryer (Dryer Repair)
by Donniewade 3/19/2017 9:03:17 AM(UTC)
Kenmore elite dryer got a thermal fuse (Dryer Repair)
by smb5769 7/9/2015 11:35:19 AM(UTC)
Kenmore Elite Dryer Intermittently Stops Running (Dryer Repair)
by CVilla 7/7/2015 9:30:28 AM(UTC)
Kenmore Elite Dryer - stops when start button released (Dryer Repair)
by bakchr 4/13/2015 11:10:30 AM(UTC)
Kenmore Elite Dryer will not run for more than a second...have done lots of troublesh (Dryer Repair)
by The_Wizard 11/10/2014 4:39:55 PM(UTC)
kenmore elite dryer touch pad replace (Dryer Repair)
by SoCal 8/1/2014 5:03:38 PM(UTC)
Kenmore elite dryer. No heat (Dryer Repair)
by Txbigfoot 7/14/2014 10:58:25 PM(UTC)
Erratic touchpad test results for failing Kenmore Elite Dryer (Dryer Repair)
by gmilo2 1/13/2014 5:49:01 PM(UTC)
Kenmore Elite Dryer Getting To Hot (Dryer Repair)
by TINAO 4/10/2013 10:06:52 AM(UTC)
Kenmore elite dryer wont start (Dryer Repair)
by trueblue9 12/28/2012 1:42:56 PM(UTC)
How to troubleshoot a kenmore elite dryer (Dryer Repair)
by JamesHom 7/1/2012 10:20:25 AM(UTC)
Kenmore Elite dryer time display jumps around (Dryer Repair)
by toddc 6/24/2012 7:40:54 PM(UTC)
Kenmore Elite Dryer - 3 beeps (Dishwasher Repair)
by Ken4230 3/21/2012 12:32:32 PM(UTC)
