dymetz62
#1 Posted : Wednesday, January 8, 2014 5:00:20 PM(UTC)
dymetz62
My dryer wouldn't run the other day.I pushed the start button and thought I heard something and that was all. I ordered a new start switch but that didn't solve it.The door switch sounds fine(clicks when pushed down) I watched the video for the thermal fuse;he said the dryer would still run.I read a post on here that said it might not run.what would be my next step.The dryer is in a tight spot so it won't be easy to get inside to the door switch.
Thank-you
Dan
fairbank56
#2 Posted : Wednesday, January 8, 2014 5:42:05 PM(UTC)
fairbank56
The dryer will not run if the thermal fuse is bad. Check continuity on that and on the door switch. The dryer has a thermal fuse and a thermal cutoff. The thermal fuse is in the motor circuit, thermal cutoff is in the heater circuit.
Eric
dymetz62
#3 Posted : Saturday, January 11, 2014 7:28:35 PM(UTC)
dymetz62
thanks,
As soon as I saw the thermal fuse; I knew it was burn't
thamks for the help
DAN
dymetz62
#4 Posted : Saturday, January 11, 2014 7:29:13 PM(UTC)
dymetz62
thanks,
thanks for the help
DAN
Guest (5)
Kenmore Elite dryer won't run... (Dryer Repair)
by J C Jones 9/11/2021 9:09:42 AM(UTC)
Kenmore Dryer won't run (Dryer Repair)
by gman536 3/14/2021 3:37:08 PM(UTC)
Dryer won't run unless start button is held down - no heat (Dryer Repair)
by jstrefeler 9/24/2017 12:10:11 PM(UTC)
Dryer WOn't Run (Dryer Repair)
by wstvpawjr13 5/14/2017 12:23:41 PM(UTC)
Dryer won't run after releasing the on button (Dryer Repair)
by Heathers1988 11/9/2016 4:20:53 PM(UTC)
Amana Dryer won't run (Dryer Repair)
by Paige Tremblay 1/26/2014 6:06:08 AM(UTC)
by pmclaughlin@apins.com 4/9/2013 11:18:38 AM(UTC)
by Ronald Walls 3/19/2013 1:09:09 PM(UTC)
by Ronald Walls 3/19/2013 1:06:28 PM(UTC)
by loumemoli 7/2/2012 1:33:54 PM(UTC)
dryer won't run but heats up fast (Dryer Repair)
by w. carroll 3/28/2012 8:22:26 AM(UTC)
Dryer Won't Run (Dryer Repair)
by paul888 1/16/2012 1:37:57 PM(UTC)
Dryer won't run after start. (Dryer Repair)
by clparks 4/28/2011 9:49:25 AM(UTC)
by tterry 3/29/2011 10:49:47 AM(UTC)
by DarrelD 1/31/2011 1:09:02 PM(UTC)
