Carreiro
#1 Posted : Tuesday, December 31, 2013 12:59:03 PM(UTC)
Carreiro
Relay and overload protector are no longer available for my fridge
So I'm forced to replacing it with a 3 n 1 start RC0410 not sure on the
Wiring I know we're the red,white & blk wires go but not sure of the other
2 black wires go
richappy
#2 Posted : Wednesday, January 1, 2014 2:44:57 AM(UTC)
richappy
Do NOT use the 3 n 1, it will blow out your compressor.
If you have a square, black item connected to two compressor terminals, that is the ptc start device. You need to make ohm meter measurements on it so I can help you.
Also, it would help to state your problem.
Carreiro
#3 Posted : Wednesday, January 1, 2014 6:57:25 AM(UTC)
Carreiro
Fridge was not staying cold compressor was not starting I took out the relay and shook it and it sounded like everything was broken inside. Yes the relay has 2 wires a pink one and a blue one and the overload protector has a black wire
I checked the compressor with an ohm and it was fine
Carreiro
#4 Posted : Wednesday, January 1, 2014 7:21:28 AM(UTC)
Carreiro
This is what I have
Carreiro attached the following image(s):
richappy
#5 Posted : Thursday, January 2, 2014 12:13:14 AM(UTC)
richappy
Make a diagram of the wires to the brown start device and order a new one.
Guest (5)
KitchenAid start relay and overload replacement (Refrigerator & Freezer Repair)
by jwforshey 5/21/2012 5:53:33 AM(UTC)
