3 Pages<123
fairbank56
#21 Posted : Friday, December 20, 2013 4:49:34 PM(UTC)
fairbank56
You should have 120vac between the orange wire and blue wire for high speed and between orange wire and white wire for low speed. You should also have 120vac between violet/white and red for the start winding. Your wiring diagram is inside the control panel. I said your timer may be faulty. I can't say for sure as I'm not there to troubleshoot your washer and it's fruitless to try and explain to a layman how to electrically troubleshoot over this forum.
Eric
Jojam3000
#22 Posted : Thursday, December 26, 2013 3:08:09 PM(UTC)
Jojam3000
Eric
I understand, I did find the schematics and had power all the way through..the timer came in yesterday I installed today.
I'm a little embarrassed by the outcome. When I initially tinkered with it I had left the harness to the motor loose(didn't clip correctly) so after I had jumped the lid switch as the machine started working the harness must of came loose.
After I installed the timer nothing happened so after further investigating I noticed the harness :mad: but now all is working and I have an extra timer for future breakdowns or diagnosing:cool:
It did need the lid switch though so thanx for your patience and help.
Joel
Whirlpool Mod# LSQ9200KQ0 washer won't agitate or spin (Washer Repair)
by Guest 5/13/2023 11:34:56 AM(UTC)
Washer won't agitate or spin out. (Washer Repair)
by tracibailey 1/11/2019 8:43:20 AM(UTC)
Kitchen Aid Washer Won't agitate or spin (Washer Repair)
by M Yaworski 7/18/2017 7:00:37 AM(UTC)
Washer won't agitate or spin, and motor won't turn (Washer Repair)
by Jimmm59 8/24/2015 9:59:30 AM(UTC)
GE Profile Top Load Washer Won't Agitate or Spin (Washer Repair)
by keikomaru 3/21/2015 2:16:27 PM(UTC)
GE Washer Won't Agitate or Spin (Washer Repair)
by TXTerry 9/21/2014 10:35:00 AM(UTC)
GE Profile Washer Won't Agitate or Spin (Washer Repair)
by WisconsinMatt 8/19/2014 11:34:42 AM(UTC)
by patkat3 6/13/2014 8:04:56 AM(UTC)
Kenmore 90 series washer won't agitate or spin (Washer Repair)
by JayDigger 1/31/2014 9:30:29 AM(UTC)
Frigidaire Washer Won't Agitate Or Spin (Washer Repair)
by paulem 10/7/2013 5:50:21 AM(UTC)
GE Washer Won't Agitate Or Spin (Washer Repair)
by Pat401 8/15/2013 3:01:45 PM(UTC)
by Stephenluck 6/12/2013 12:34:39 AM(UTC)
GE washer won't agitate or spin- no error codes (Washer Repair)
by Mark Falcon 5/13/2013 6:12:26 PM(UTC)
Washer won't agitate or spin, can turn motor by hand (Washer Repair)
by englaisfitz 11/14/2012 5:49:24 AM(UTC)
washer won't agitate or spin, goes through cycles, fills and drainss (Washer Repair)
by kb4bill 6/4/2012 12:58:12 PM(UTC)
3 Pages<123
