RJB
#1 Posted : Saturday, May 2, 2009 6:38:56 AM(UTC)
RJB
The water's OK the power's OK but the washer doesn't run. When I start the cycle (any cycle) and close the door nothing happens. Well yes, the water heater does come on as I can feel the heat from it inside the washer. I can't seem to find any documentation on this model. Any help out there?
#2 Posted : Saturday, May 2, 2009 3:26:57 PM(UTC)
Very likely the problem is a bad circulation pump. You have to remove the dishwasher from the cabinet and remove the right side panel to access it.
- The part number for the circulation pump is AP3842231
RJB
#3 Posted : Sunday, May 3, 2009 6:08:33 AM(UTC)
RJB
Thanks, Gene
I've pulled the washer out, but diging into the side panel looks daunting. Lots of insulation and stuff. Are there any manuals available for this model to tell me the correct order of disassembly?
I've removed the inner parts and gotten to what appears to be an impeller at the bottom of the tub. Turning it with my finger it feels a little stiff.
Dishwasher won't run cycles, only fills a bit (Dishwasher Repair)
by Snowfinch 7/7/2015 7:06:10 AM(UTC)
Kitchenaid Dishwasher won't run ? motor (Dishwasher Repair)
by garywool93 8/30/2013 1:23:19 PM(UTC)
Dishwasher won't run (Dishwasher Repair)
by thebling 2/21/2013 9:37:53 AM(UTC)
Whirlpool GU1500XTLT Dishwasher Won't Run (Dishwasher Repair)
by fishingbear 5/5/2012 8:15:09 AM(UTC)
Dishwasher Won't Run/Air Dry Light Flashing (Dishwasher Repair)
by Coyote1cf 1/16/2012 10:42:09 AM(UTC)
KitchenAid dishwasher won't run (Dishwasher Repair)
by johnniered 12/30/2010 9:26:32 AM(UTC)
GE Dishwasher won't run (Dishwasher Repair)
by Logan29 11/21/2010 5:55:12 PM(UTC)
Dishwasher won't run full cycle (Dishwasher Repair)
by Jp4me 8/15/2010 10:27:10 PM(UTC)
Dishwasher Won't Run/Drain (Dishwasher Repair)
by k5sparks2 2/17/2010 12:05:43 PM(UTC)
KitchenAid Dishwasher Won't Run (Dishwasher Repair)
by john roberts 9/14/2009 3:10:11 PM(UTC)
by jotisch 9/2/2009 9:10:50 AM(UTC)
Kitchen Aid Dishwasher won't run cycle (Dishwasher Repair)
by mscoop 4/29/2009 6:45:10 PM(UTC)
Whirlpool dishwasher won't run (Dishwasher Repair)
by AmateurTech 3/15/2009 6:48:20 AM(UTC)
frigidaire dishwasher won't run (Dishwasher Repair)
by utahskierdave 1/18/2009 10:40:58 AM(UTC)
Dishwasher won't run - "Normal" light flashing (Dishwasher Repair)
by awright 11/3/2008 8:53:26 PM(UTC)
