hsellman
#1 Posted : Saturday, May 2, 2009 9:18:18 AM(UTC)
hsellman
the detergent door will not lock closed can this be replaced or repaired by owner? It is the Gold model. number above ser # is fr07018275 serial gu1500xtls3. purchased april 2004
#2 Posted : Tuesday, May 5, 2009 2:27:12 AM(UTC)
Replacement parts for WHIRLPOOL GU1500XTLS3 | AppliancePartsPros.com
Here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%208537797.pdf
And a service manual
https://secured.whirlpoo...0ef763c85256cbc00520548/$FILE/8178022.pdf
Problem can be due to 3 causes:
1. Mechanical
2. Dispenser assembly solenoid/motor is shot
3. Dispenser is not receiving power from the control when it should.
Remove the inner door panel and check the detergent assembly for a visual mechanical fault. Also check the wires going to the solenoid/motor on the dispenser.
Check the release motor resistance, see the tech sheet, if open (infinite resistance), the dispenser will have to be replaced.
Run the diagnostics.
