I'm planning to replace the ignition control board on my Carrier gas pack. There's one step I don't understand however. That is, how do I disconnect the ignition wire from the control board? The ignition wire looks like the spark plug wire on a lawn mower. It connects to what looks like a small coil on the control board. It's not obvious to me how to disconnect the wire and re-connect it to the new control board. Do I just pull it out of the coil? Or is there something I need to do to release it before I pull it out? Here's a link that shows a picture of the board. The ignitor connector is the round object near one end of the board. It stands up higher than anything else on the board. thanks!
Just pull hard. It will come off. You may be able to slide the rubber part back then grab it with a set of needle nose and pull it off.make sure the power is off to the unit first.
