calcalicut62
#1 Posted : Monday, February 4, 2013 4:16:30 PM(UTC)
calcalicut62
I am getting a 7E code for model #WF306LAW/XAA...what part number is the board? I never use Silvercare!
Whitehorse
#2 Posted : Saturday, November 30, 2013 9:11:06 AM(UTC)
Whitehorse
I'm having the same problem. Did you solve the issue? I just tried replacing the AG PCB (AG3MOD-S2LF) but that didn't do anything. Any 'been there' advice you can give is appreciated.
calcalicut62
#3 Posted : Saturday, November 30, 2013 1:24:51 PM(UTC)
calcalicut62
I ended up replacing the small control board in back of the machine (on top below water inlets) AND the small board next to the control panel..it was NOT the silver care unit.. We never hardly used the silvercare. The board in back ties into the silvercare unit...try to replace the small board on the rear upper portion of the machine near the water valves/inlets. I probably did not need to change out the small board in front...it did not hurt anything and part was also cheap.
