2 Pages<12
Fisheyeii
#11 Posted : Sunday, November 17, 2013 3:04:04 PM(UTC)
Fisheyeii
Rank:: Member
Checking with a small inspection mirror, I can see that the baffle is wide open. When I put it into diagnostic mode the fan baffle cycles open-closed-open-closed but the fan is not running. (I think it is supposed to be running during this test.) So the baffle does not appear to be binding or iced up and frozen open but it does appear to be always open.
Yesterday you asked if the vegetable bin drawer vent was frosting even when closed. This morning I cleaned it and closed it. Now, eight hours later, there is frost collecting around the outside of the slide housing.
Thanks for sticking with me on this thread!
Appliance Ninja
#12 Posted : Sunday, November 17, 2013 3:42:50 PM(UTC)
Appliance Ninja
I believe you have a control issue. All of the slave components, like the fan, baffle, etc are working fine. The damper with the thermistor was replaced, so it should be closing. I would recommend replacing the control, available at the link below.
Whirlpool 8201527 Microcptr - AppliancePartsPros.com
Fisheyeii
#13 Posted : Sunday, November 24, 2013 4:38:08 AM(UTC)
Fisheyeii
Rank:: Member
The new control board installed with out problems and in the diagnostic mode the baffle opens and closes. However, even on the lowest settings for freezer and refrigerator, it is 30 degrees in the food compartment. I have not check the freezer temperature but the ice cream is as hard as a brick! I listen for the evaporator fan every time I walk through the kitchen. It always seems to be running, even first thing in the morning when the door has not been open all night. Could there be a thermostat issue, inspite of the "good" diagnostic mode reading?
Appliance Ninja
#14 Posted : Sunday, November 24, 2013 8:33:03 AM(UTC)
Appliance Ninja
That is really odd. Sorry you are still having trouble with it. You replaced the thermistor shown as number 5 in the picture below?
Appliance Ninja attached the following image(s):
Fisheyeii
#15 Posted : Sunday, November 24, 2013 9:55:00 AM(UTC)
Fisheyeii
Rank:: Member
Yes, I replaced that with the new baffle. Are there resistance values I can check? Is the second thermistor the same?
Appliance Ninja
#16 Posted : Sunday, November 24, 2013 10:11:16 AM(UTC)
Appliance Ninja
Sure, the thermistors may be tested using the temperature chart below.
2 Pages<12
