LarryY
#1 Posted : Friday, November 22, 2013 11:21:40 AM(UTC)
LarryY
This is a wine cooler with a bad thermostat - order new part and installed it - unit seemed to work fine until I closed the back and mounted the stat - doesn't work at all. I assume I did something wrong and don't want to repeat with second new thermostat - any help would be appreciated
Appliance Ninja
#2 Posted : Friday, November 22, 2013 11:33:25 AM(UTC)
Appliance Ninja
What is it doing now? Could you have possible shorted a ire to ground while installing or ran a screw through the thermocouple from the thermostat?
LarryY
#3 Posted : Friday, November 22, 2013 11:36:43 AM(UTC)
LarryY
Doesn't do anything - will work if I bypass the thermostat - I dont see any damage to the thermocouple, I thought I ran it along the same path
Appliance Ninja
#4 Posted : Friday, November 22, 2013 11:49:09 AM(UTC)
Appliance Ninja
So no continuity through the thermostat terminals if tested with a meter? Doesn't sound like you did anything unless it shorted, but you would have noticed that.
LarryY
#5 Posted : Friday, November 22, 2013 12:06:51 PM(UTC)
LarryY
No continuity - it seemed to work until I put it together - I jumped the wires and it worked - I thought maybe I broke or kinked the thermo couple but can't see anything
Appliance Ninja
#6 Posted : Friday, November 22, 2013 12:08:16 PM(UTC)
Appliance Ninja
It sounds like the thermostat is just faulty. It should be under warranty and not cost anything for a replacement.
LarryY
#7 Posted : Friday, November 22, 2013 12:10:30 PM(UTC)
LarryY
Thanks so much for the help - will call on it
Appliance Ninja
#8 Posted : Friday, November 22, 2013 12:13:24 PM(UTC)
Appliance Ninja
You are very welcome, have a great weekend!
