pmplatisha
#1 Posted : Friday, November 22, 2013 7:11:18 AM(UTC)
pmplatisha
I ordered and received the door assembly part # ADC49436904 from Applianceparts pros but there were no installation instructions. How do I remove the old door and replace with the new ?
Appliance Ninja
#2 Posted : Friday, November 22, 2013 7:51:44 AM(UTC)
Appliance Ninja
You will need to first remove the grille from above the door. Once that is removed, open the door and lift it straight up from the hinge pins and pull it off. The new door will install the same way, but you will need to align the hinge pins with the holes in the door.
