2 Pages12>
SFPhoto
#1 Posted : Sunday, November 17, 2013 8:40:13 AM(UTC)
SFPhoto
Does not drain. Hose is clear, as is path to check valve within the washer (all interior components removed/inspected).
What are the functions of the relay and the switch, could they be the problem? The switch tests fine - it is activated by a float.
Washing function seem to work fine, I assume the motor/pump (one unit on this model) is not getting the signal to drain the water OR that part of the motor/pump has failed.
Appliance Ninja
#2 Posted : Sunday, November 17, 2013 10:31:23 AM(UTC)
Appliance Ninja
On this model, the motor reverses to drain. When it is supposed to be draining, does the motor make any noise, like humming or buzzing or does it just sit silently?
SFPhoto
#3 Posted : Sunday, November 17, 2013 11:59:00 AM(UTC)
SFPhoto
Thanks for your response.
No buzzing, could be a hum or silent. Ran the rinse only cycle w/ no heat dry - it make lots of noise while rising then pretty quiet after that.
Any way to test the motor/pump?
Appliance Ninja
#4 Posted : Sunday, November 17, 2013 2:46:45 PM(UTC)
Appliance Ninja
Okay, so it never pumps out?
SFPhoto
#5 Posted : Sunday, November 17, 2013 5:37:31 PM(UTC)
SFPhoto
Nope, 3 inches in the bottom.
Sears is out of stock on the motor but I think it is returnable if and when I were to obtain one and that is not the problem.
Not sure if there is a way to test the motor. DW has been "uninstalled".
Appliance Ninja
#6 Posted : Sunday, November 17, 2013 5:48:17 PM(UTC)
Appliance Ninja
If you put the machine to a drain cycle, you can see if the motor is getting power. If it is, you will usually, but not always, hear it at least humming or buzzing.
SFPhoto
#7 Posted : Monday, November 18, 2013 8:34:02 AM(UTC)
SFPhoto
Can it be tested dry - by seeing if power is going to the motor after the rinse cyclc?
I would set to just rinse w/ no heat with the unit out of the cabinet.
Can you perhaps point me to a schematic to see what wires to the motor do what? I assume white is (+ or -)power and the others get power only during certain phases of the cycle.
Appliance Ninja
#8 Posted : Monday, November 18, 2013 8:43:01 AM(UTC)
Appliance Ninja
Test between white and red at the motor with the machine set to drain. Do you read 120 VAC between those two wires?
SFPhoto
#9 Posted : Monday, November 18, 2013 9:49:29 AM(UTC)
SFPhoto
This photo shows details of the unit. Leads are: white-blue-blue/red-blue/black. There is no indication of when it is draining.
https://www.dropbox.com/s/4ifsjviaox1uwdv/kenmore.jpg
I can set to rinse/hold and check all the leads (using white as common) while rinsing and when the power drops from the lead supplying power during rinse check the others. This would assume that power goes to a different lead for draining.
Appliance Ninja
#10 Posted : Monday, November 18, 2013 9:52:52 AM(UTC)
Appliance Ninja
The wire with the red trace is the winding that should be energized when it should be pumping, so white to that wire should read 120 VAC when it should be pumping out.
Guest (5)
Water is left in washer, door is locked cannot open, does not drain, clothes still wet (Washer Repair)
by Guest 12/4/2022 11:52:36 AM(UTC)
washer does not drain (Washer Repair)
by lukasage 8/31/2015 4:42:43 AM(UTC)
Washer does not drain (Washer Repair)
by erichawkinsa 3/30/2014 6:10:08 PM(UTC)
Dishwasher does not drain completely (Dishwasher Repair)
by jlobb2 12/4/2013 2:42:17 AM(UTC)
by jlobb2 12/4/2013 2:40:46 AM(UTC)
Whirlpool Quiet Partner II does not drain (Dishwasher Repair)
by JosephC 11/12/2013 2:30:21 PM(UTC)
Whirlpool dishwasher does not drain (Dishwasher Repair)
by valv00 3/30/2013 5:05:23 PM(UTC)
Does not drain (Washer Repair)
by Moesmom 2/24/2013 2:32:45 PM(UTC)
Fridgidaire Gallery Does not drain water (Washer Repair)
by Abe460 12/30/2012 4:58:39 PM(UTC)
Water does not drain completely (Dishwasher Repair)
by g11171 9/17/2012 5:28:01 PM(UTC)
Whirlpool Washer does not drain (Washer Repair)
by L-Squared 8/13/2012 4:31:44 PM(UTC)
Jenn Air Dishwasher does not drain completely (Dishwasher Repair)
by jjdoc 6/26/2012 11:41:48 AM(UTC)
Washer puts water in drum does not turn only hums and water does not drain (Washer Repair)
by vsquared 6/23/2012 7:09:22 PM(UTC)
dish washer does not drain completely (Dishwasher Repair)
by billnheather 5/27/2012 5:33:36 PM(UTC)
MAH6500AWW ND CODE. Does not drain. (Dishwasher Repair)
by Rocketboz 5/25/2012 8:17:59 PM(UTC)
2 Pages12>
