2 Pages<12
Kestryll
#11 Posted : Wednesday, November 13, 2013 6:05:35 PM(UTC)
Kestryll
Originally Posted by: Appliance Ninja Go to Quoted Post
The picture did not come through, sorry. The setting will be marked Rx1 or have a horseshoe looking symbol. When the probes are touched together, the needle should move.
It's a digital one. I'm assuming i need to test where the prongs enter the control unit. Assuming I'm doing it right I'm getting nothing on voltage and getting a resistance reading
Appliance Ninja
#12 Posted : Wednesday, November 13, 2013 6:06:56 PM(UTC)
Appliance Ninja
Are you testing the white fuse that is mounted near the edge of the board?
Kestryll
#13 Posted : Wednesday, November 13, 2013 6:18:18 PM(UTC)
Kestryll
UserPostedImage
Maybe this will work. The one in the middle? Yes I'm testing it. No reading
Appliance Ninja
#14 Posted : Wednesday, November 13, 2013 6:44:15 PM(UTC)
Appliance Ninja
Awesome, that board is bad and the reason your machine is not tumbling! Very well done! That board you need is available below!
Frigidaire 134149220 Speed Controller Assembly - AppliancePartsPros.com
Kestryll
#15 Posted : Wednesday, November 13, 2013 6:46:09 PM(UTC)
Kestryll
I hope it's worth it replacing that board in this machine.
Appliance Ninja
#16 Posted : Wednesday, November 13, 2013 7:00:00 PM(UTC)
Appliance Ninja
If the tub is not real noisy when it spins, it probably is.
Kestryll
#17 Posted : Wednesday, November 13, 2013 7:03:03 PM(UTC)
Kestryll
Tub sounds about the same as it did 10 years ago when we got it (minus all that damn change stuck inside it, i need to figure out how to get it out)
Thank you for all your help
Kestryll
#18 Posted : Friday, November 15, 2013 6:18:05 PM(UTC)
Kestryll
Receieved the part today. Works like new. Thank you so much
Appliance Ninja
#19 Posted : Friday, November 15, 2013 7:05:39 PM(UTC)
Appliance Ninja
That is great news, nice work! Thank you for taking the time to share your success story, I appreciate that!
icfman
#20 Posted : Monday, December 23, 2013 7:09:45 AM(UTC)
icfman
Hello Appliance Ninja, I have the same problem - everything except spin. I have replaced the pressure/level switch, the door lock assembly and the speed control board and still no spin. Pump out is fine, fill and water level fine, tub back and forth tumble is fine, just no final spin. Any ideas? Thanks
Guest (10)
2 Pages<12
