They will be single wires on the relays marked with a yellow dot. Those wires run down to the bake elements.
I have the two yellow shown here. Going into the panel back I will pull both. Tape off Wire end. Then apply power to the oven. Turn on oven, then test connection at panel ?
[IMG]https://mail.google.com/mail/?ui=2&ik=20d9c5d003&view=att&th=1425953af2d75adb&attid=0.1&disp=thd&zw[/IMG]
Correct, turn each oven to bake and measure power at the now empty terminals and see if they read 120 VAC from the terminals to ground.
please point me to ground. dont wanna die tonight
Any metal surface on the oven is ground. Sorry I did not clarify that.
Done - 0 on each test. Some Clicking of Relays.
Thanks for the Help. I guess cheaper than a whole new unit. I really appreciate the guidance.
You are very welcome, you did a great job! Let me know if you run into trouble during installation of that control.
Hi Ninja, Received the new control unit. But - More connections on this one than the old one... Are we sure this is a one for one newer part?
