2 Pages12>
torrealtl1
#1 Posted : Wednesday, November 13, 2013 9:39:51 AM(UTC)
torrealtl1
Due to the Dryer wasn't start on and off, I changed the Door Switch, but the problem still. What other parts I need to verify to find the problem?
Appliance Ninja
#2 Posted : Wednesday, November 13, 2013 10:01:42 AM(UTC)
Appliance Ninja
When you start the dryer, do you hear a click from the area of the control, even though the dryer does not start?
torrealtl1
#3 Posted : Wednesday, November 13, 2013 10:10:00 AM(UTC)
torrealtl1
The front panel still on and you can hear a click in the control area every one or two minutes.
torrealtl1
#4 Posted : Wednesday, November 13, 2013 10:12:29 AM(UTC)
torrealtl1
The front panel still on and you can hear a click in the control panel every one or two minutes. I disconnect from the main power to avoid hear the click.
Appliance Ninja
#5 Posted : Wednesday, November 13, 2013 10:22:48 AM(UTC)
Appliance Ninja
Thank you! Do you have a meter to test with? You may have an open thermal fuse or a faulty control board. I would hate to guess....
torrealtl1
#6 Posted : Wednesday, November 13, 2013 11:15:04 AM(UTC)
torrealtl1
Yes, I have a continuity meter, I will verify for continuity. Thanks for your help.
Appliance Ninja
#7 Posted : Wednesday, November 13, 2013 11:17:33 AM(UTC)
Appliance Ninja
There are two thermal fuses in line with the wire from the control that feeds the motor. One of them has likely opened. Let me know if you need help accessing and testing them.
torrealtl1
#8 Posted : Wednesday, November 13, 2013 11:44:19 AM(UTC)
torrealtl1
How to do it, and were are located?
torrealtl1
#9 Posted : Wednesday, November 13, 2013 11:45:45 AM(UTC)
torrealtl1
How I will do it, and were are they located?
Appliance Ninja
#10 Posted : Wednesday, November 13, 2013 11:51:24 AM(UTC)
Appliance Ninja
Number 10 in the first diagram is mounted on the blower housing and number 11 in the second diagram is mounted on the can where the fire is. You can test those to be sure they show closed, or have continuity to allow the current through.
Guest (6)
2 Pages12>
