joanu
#1 Posted : Wednesday, November 13, 2013 9:32:59 AM(UTC)
joanu
Gas oven will not heat up to temperature. Also, Will not preheat past 100 degrees
Appliance Ninja
#2 Posted : Wednesday, November 13, 2013 9:53:26 AM(UTC)
Appliance Ninja
Can you tell if the burner is lighting at all? Can you please double check that model number?
joanu
#3 Posted : Wednesday, November 13, 2013 10:12:45 AM(UTC)
joanu
Occassionaly I'm getting some heat There's times I get nothing at all. Ithink the first three characters may be 3EF. It's so very hard to read as I have vision problems
Appliance Ninja
#4 Posted : Wednesday, November 13, 2013 10:20:19 AM(UTC)
Appliance Ninja
Thank you. The igniter is likely weak and not opening the gas valve as it should be. Over time, they get weak and will not draw the current required to open the valve, that is very common. The model number is too far off for me to get you an accurate part number. Do you have a magnifier you may be able to use as it is very important to get the correct part?
joanu
#5 Posted : Wednesday, November 13, 2013 10:26:44 AM(UTC)
joanu
best i am able to read is:3efvf03124098. other than that i'll have to wait til my neighbor comes home. thank you ever so much!! Joan
Appliance Ninja
#6 Posted : Wednesday, November 13, 2013 10:39:33 AM(UTC)
Appliance Ninja
I understand, thank you. Just post back that model when you can and I will get you a link to the part you likely need.
joanu
#7 Posted : Thursday, November 14, 2013 4:31:11 AM(UTC)
joanu
Appliance Ninja: Here is the information you requested yesterday. My neighbor came over and read the correct info for me:
Model: FGF376CJSA Ser. No: VF03124098 I hope this is the correct info.You have been such a GREAT help to me! My children, grand children and great grand children thank you!
You did say you would send me a link to the right part number?..Next, how do I install it. Thank you AGAIN jOAN
Appliance Ninja
#8 Posted : Thursday, November 14, 2013 7:15:45 AM(UTC)
Appliance Ninja
Thank you, Joan, that is perfect! The igniter I believe you need is available at the link below. There is also a video at that link showing how to replace it! If you have trouble once you receive the part, simply post back and we can walk through it together!
Frigidaire 5303935066 Oven Igniter - AppliancePartsPros.com
