AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
GE Profile PT970BM1BB Microwave Buzzes when Door is Shut
My 4.5 year old GE Microwave PT970M1BB Buzzes Loudly when the door is shut. This microwave is built-in with an Oven below.
Loud buzzing starts immediately when the door is shut.
So far, I have replaced the Transformer, Magenetron & a plastic "Air-Cover" (basically a duct that goes between the Magenetron & the side wall of the microwave cooking chamber).
The original "Air Cover" was melted on top so I assumed the Magnetron was overheating causing this problem.
I just completed the replacement of all these parts and when I shut the door the buzzing starts and I see some "whisps" of smoke coming up from the magenetron. I am not sure if this is just because it is new and needs to break in a little and burn off some paint or if this is another symptom of the real problem.
I called one of the sales folks and they looked up my problem and said that other Posts have indicated either a bad door switch or the control board for the microwave.
Hopefully this will be a relatively cheap-fix since I have already sunk alot of money and time into this unit.
Thanks for your help.
Bill
Originally Posted by: bill@billory.com ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My 4.5 year old GE Microwave PT970M1BB Buzzes Loudly when the door is shut. This microwave is built-in with an Oven below. Loud buzzing starts immediately when the door is shut. So far, I have replaced the Transformer, Magenetron & a plastic "Air-Cover" (basically a duct that goes between the Magenetron & the side wall of the microwave cooking chamber). The original "Air Cover" was melted on top so I assumed the Magnetron was overheating causing this problem. I just completed the replacement of all these parts and when I shut the door the buzzing starts and I see some "whisps" of smoke coming up from the magenetron. I am not sure if this is just because it is new and needs to break in a little and burn off some paint or if this is another symptom of the real problem. I called one of the sales folks and they looked up my problem and said that other Posts have indicated either a bad door switch or the control board for the microwave. Hopefully this will be a relatively cheap-fix since I have already sunk alot of money and time into this unit. Thanks for your help. Bill Hi Bill, We have same issue with our GE Profile Microwave..when shut the door some buzzing sound. you mentioned Bad door switch or control board..how did you fix it? Please let me know Thanks in advance
I ended up replacing the Control Board and all was OK after that.
Check your Air Duct and make sure it is not melted - If it is, I would recommend replacing it while you have the unit torn apart.
Good Luck
Bill
Originally Posted by: bill@billory.com ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I ended up replacing the Control Board and all was OK after that. Check your Air Duct and make sure it is not melted - If it is, I would recommend replacing it while you have the unit torn apart. Good Luck Bill Thanks Bill!!
Microwave Repair
