opeter
#1 Posted : Wednesday, November 6, 2013 9:27:43 AM(UTC)
opeter
I have a Jenn-Air Range top.
Only certain functions (buttons) on the Control Panel touch pad work.
Can I test the Panel to see if it indeed needs to be replaced? Can it be a separate issue? Or can I pretty much assume that it needs replacement?
(Keys 7, 8, 9) do not work on touch pad. But all the rest do!
Thank you for your reply!
#2 Posted : Wednesday, November 6, 2013 11:16:52 PM(UTC)
Parts for Jenn-Air JGS8750ADS Range - AppliancePartsPros.com
The problem could be either the control panel or the control board/timer.
The tech sheet does have the control panel pin-outs so you can check it.
Note that track 4 in the ribbon cable is common to all 3 keys that do not work.
You may want to try the following
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
File Attachment(s):
JGS8750.pdf (527kb) downloaded 27 time(s).
opeter
#3 Posted : Monday, November 18, 2013 10:49:05 AM(UTC)
opeter
Thank you for your response denman
I did as you suggested and cleaned the contacts, but unfortunately the 7,8,9 keys still do not operate.
Unfortunately at this point I don't know if its the control board, the ribbon cable or the keypad. Any suggestions?
Thank you
#4 Posted : Monday, November 18, 2013 11:05:01 AM(UTC)
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
