Tigerhawk247
#1 Posted : Tuesday, November 5, 2013 7:14:29 PM(UTC)
Tigerhawk247
Hi,
My washer has suddenly stopped spinning during the wash cycle. It fills with water, then I hear nothing and it eventually drains. I thought at first it was maybe the load, so I emptied it and just tried doing another cycle...same thing happens. It completely fills and then eventually drains with nothing in it without spinning/agitating.
Before I call my home warranty and pay a repair guy I was wondering what are some easy things to check for this particular model?
Any and all help is truly appreciated!
~T
fairbank56
#2 Posted : Wednesday, November 6, 2013 4:30:35 AM(UTC)
fairbank56
Take the front panel off by inserting putty knife into the front of the top groove in line with the lid opening on each end to release the clips while pulling on panel. Tilt out and lift from cabinet. Check circuit board on top of motor. Should be a flashing LED on the right side of the circuit board that will indicate error codes. What is the flash rate?
Eric
Tigerhawk247
#3 Posted : Wednesday, November 6, 2013 9:28:26 AM(UTC)
Tigerhawk247
Hi,
I'm at work now and won't be home until late tonight. I'll post it as soon as I can.
GE Washer not spinning (Washer Repair)
by zoobteach 8/29/2015 10:12:50 AM(UTC)
by atomicsynth 6/2/2015 10:36:31 PM(UTC)
GE washer not spinning any cycle (Washer Repair)
by j409 6/2/2014 7:44:19 AM(UTC)
GE Washer not Spinning (Washer Repair)
by jkomes 12/19/2013 6:52:43 PM(UTC)
GE washer not spinning out all the water (Washer Repair)
by sbryant73 11/16/2013 2:51:08 PM(UTC)
by jschust 10/6/2013 9:17:23 AM(UTC)
GE washer not spinning (Washer Repair)
by dorlando 7/13/2013 6:06:17 PM(UTC)
by jlbyrnes3 4/8/2013 10:54:18 PM(UTC)
by JD0034 1/1/2013 5:13:24 PM(UTC)
by mau397 5/6/2012 2:38:20 PM(UTC)
GE Washer not spinning and smells strange (Washer Repair)
by greenfelt22 7/26/2011 6:26:28 AM(UTC)
GE Washer not spinning. Bad motor or transmission? (Washer Repair)
by MrJosh 6/17/2009 7:02:48 AM(UTC)
