My Kenmore dishwasher has the Quick Rinse button LED flashing continuously. No other buttons will work. Tried turning breaker off to reset, no help. Any suggestions as to problem and solution?:confused:
The flashing Quick Rinse LED means on or more pads on the key pad are stuck. In order to fix the problem the control panel has to be replaced. - The part number for the control panel (black) AP3138247 - The part number for the control panel (white) AP3128379 Gene.
